Re: MIRROR
I know LMC tru [img]/ubbthreads/images/graemlins/shrug.gif[/img]ck has that type of mirror. Don't know if it's stainless or what quality they are, but worth a try.
--motor/trans sold--
2000 VW Jetta TDI = 48+mpg
1997 Dodge 3500: 2WD Cab & Chassis, 12V Cummins, 47RE Automatic, Dana 80, 194,000mi. Parting out.
1989 12V VE Cummins out of Chevy C60? at the machine shop...going into the Ford.
Member of Indiana Air National Guard 122FW MXS
