Re: Clutch Question
If you have a good dual mass use it......cost is usually $1200.
DMWF is designed to save the trans and absorb the shock of the diesel engine.....Moving to a single mass may cause extra gear noise.... as it does not absorb the diesel shock..
This is whats confusing me. If the single mass cause extra gear noise and not save the trans then why use it? I thought about going for the single mass because it was cheaper but now I am wondering what would be good for the money............. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
Well can anyone tell me the sensibility of the single mass clutch vs the dual mass???? [img]/ubbthreads/images/graemlins/smokin.gif[/img]
David and his Ford truck with a little motor and a big idea......
Ford F-350 Dually Crew Cab 5-Sp 7.3 IDI Centurion Conversion. No mods, rebilt IP and replaced injectors. Used as personal driver and pulling my RV camper.
Planned upgrades are a new and better turbo and larger exhaust pipes than the 21/2s that are already under the rig/ would like a 6 spd tranny but dont know if that is a feasable or smart investment yet.
1993 Dodge 3/4 ton Van Conversion 318CI
1978 Dodge Magnum XE T-top Classic 4BBl 400CI (Honeymoon Car)
1965 Dodge Polara 4 DR 383CI
AmaMoparmanbutlikeForrrrrdtrucks
