Re: hard start/ no start question more
thanks all for all the suggestions. to clarafy, the previous owner was already using starting fluid to start as the hard starting problem was inhereted from the previous owner. yes I should know better than to use sf however I did try to minimize any damage by letting the auto glow plug relay to stop heating and let the glow plugs cool before attempting to start. When I changed the fuel filter I filled it with diesel fuel and let sit,refilled it and then had my son crake it over and I craked the the line going to the IP till I a steady flow of diesel. I have heard that if the return lines are leaking, they can introduce air into the system and then the IP cannot develop enough presure to off seat the Injectors. I just got some Vitro o-rings for the injectors and some bio-diesel compatable hose from a local parker seal dealer and will replace both this weekend. btw, when I changed the GP's half did not work when hooked up to 12V 4 did so left those and replaced the bad ones. cdnsarguy, I did't releaze there was a check valve in the tank. will check that also. crossbones2 will also try your suggestions. thanks agan
1988 Ford F250 XLT running B20
