Re: Grease points?
If you truck is original...there will be no grease points on the up and lower ball joints,...... tie rod ends and stabilizer bars, steering linkages yes. There is one on the driveshaft slip joint (ext cab). There may be some on the universals if they were changed.
Back to the ball joints.... get a needle adapter for the grease gun. clean an area on the rubber boots on the ball joint(s).....poke the needle in thru the rubber and fill with about 4 pumps of quality/synthetic grease. I did this in 93 and I still have 3 of the original ball joints.
Proud Canadian BOOB man too!!
