Re: Hypertech programmer
Well you can use the dual fuel setting and still run 87 in your truck.
You can use the programmer on ANY truck as long as the application number is the same. You MUST return the truck to the stock program before loading a different truck with the programmer.
I have a HYPERTECH PPIII and it brought the truck back into the power band. I lost ALOT of power with the larger tires and wheels. I really have enjoyed the PPIII and I would recommed it if you don't want to install a chip. No way are you gonna gain 50+hp. I'd have to see DYNO sheets on that one.
2006 F-350 CC PSD Lariat 4X4 LB 3.73 LS
Some stock stuff, some modded stuff, some "deleted" stuff.....
