Re: FAST IDLE PROBLEM BUT NO LIGHT ON...PLEASE HELP!!!
When I come to a stop, my idle is around 1150 RPM in gear. When I select nuetral or park the idle races up to 1500 - 1700. When I stab the throttle the idle returns to normal. This doesn't happen all the time.
The engine light is not on, so does this mean it isn't a TPS, or an idle control sensor? Could it be mechanical? I checked the cable and the pedal mechanism, it all looks good. What about disassembling the throttle body and cleaning it? It does have 170K miles on it.
Thanks,
Chris
I might check for leaks in hoses. Especially the one coming off the EGR hose on the right side leading to the top of the engine. Mine had a hole in it and was letting air into the engine w/o getting metered by the MAFS. The hole was not in the EGR hose itself it was on the hose that is like an elbow connected to the EGR hose. Hope it helps!
1999 F250 XLT, 6.8L V10 4X4 5-speed Manual w/ Precision 4.88 gears. 8" Edge/(4) Custom Valved 7100 Reservoir Shocks/ORU Dress-Up Kits/SJ Braided Fr&Rr SS Brake Lines/Edge Dual Steering Stabilizer/Aluminum Pan Rod Bar/12" HAD Long Slip Fr: Driveshaft/38" PJ's/16x10 M/T II's. Front & rear ARB's w/ Dynatrac HD Nodular Iron front & PML sand-cast finned aluminum black powder coated rear covers. Vent Visors & Bug Shield, Airaid FIPK, Granatelli MAFS, Edelbrock Twin 62MM TB, Borla SS Headers w/ Y-Pipe, FM Cat-Back w/ 30 Series Muffler, Gibson 3x4x12 SS Tip, 2 Stage 4 Bank Custom Diablo Delta w/ LED & Toggle Switch, Acetoned Badging, Westin Nerfs, Putco Racer SS Grille, Xenon Sport Flares, Smittybilt Outland Gaurds front and rear, PIAA 60XT Driving w/ Mcgard Lamp Locks, 959 Projector Fog w/ Anti-Theft Device, Extang Black Max Tonneau and a Python 1000ESP Alarm. http://community.webshots.com/user/georger121
