Re: Excursion hitch
It is a riveted on unit because it is a part of the safety feature of the truck, It has to be there, like the crash bar behind the valance in the front. No one makes one as economical as OEM. It will fit perfect. The problem is getting the old one off. The best way is heat but you are awful close to the fuel tank so most will chisel them off. I am constantly sanding and painting mine, if i could sand blast it I would rhino line it.
Some people are like Slinkys. They are good for nothing but still put a smile on your face when you push them down a flight of stairs. 2003 X Limited Ultimate, Mineral Grey Metalic. DVD, Limited Slip, Badged, Cab Lights, Magnaflow, Thule Rack, 3" Lift, T Prodigy, Air Bags, Edge Programer, XM Radio, Extreme sound system. 315/70/17s on AR Chrome/Aluminium. http://community.webshots.com/user/stellinm
