Diesel Forum - TheDieselStop.com - View Single Post - OEM Tire Problems?
Old 05-02-2007, 09:25 PM   #1 (permalink)
curlysir
OEM Tire Problems?
I have an 05 X Limited with 15,000 miles. The OEM tires are BF Goodrich LT265-16-E RWL. They were just replaced under warranty because of cracks around the circumference on all 4 tires. These were not weather checking but actual cracks running the full circumference of all 4 tires about 1 inch from the rim. The spare did not have this problem and the vehicle is stored under a carport so they were not exposed to the sun. And I check the pressure on a regular basis. Manufacture date of the tires was early 05. I have not read anything about this problem so I don't know if its widespread or not. They replaced the tires with the same tire so I don't have the warm fuzzies about them. If they had not been replaced under warranty I would have replaced them myself. The Service Advisor said that Ford approved the replacement very quickly. I guess Ford is a little leary of tire problems after Firestone.
Has anyone else had this problem with these tires?
2005 6.0 PSD Excursion Limited Secert Service Edition (Black), 4X4.
curlysir is offline   Reply With Quote
