Re: Looking to buy Excursion
As a passenger in both options I like the bench better. In the quads I felt out of loop and more like a passenger no dvd either. If there is nobody next to you in the back you will want to be in on the conversations that may be occuring w/ the 2 up front. W/ the bench you can slide to the center and ruin any conversation and get all the attention you need. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
2003 E350 7.3L Extended Cargo - No Windows - Dipricol Optix: Pyro, Trans, boost - Walker BTM - Bellowed Up-Pipes - DP Tuner No Start, Stock, 60T, 80E, 120 Tailgaters special - Spectra Premium Fuel Tank Hutched & Harpooned (Ford Tank delaminated), Dual CAT Pre-pump Filter Setup
2003 GMC Sierra 2500 6.6L LB7 - Cognito UCA's, Bilsteins, Powdercoated H2's on 315 BFG AT's, PPE Standard
1993 Ford F250 7.3L "Black Beauty" 278K miles & is used to take the dogs out to play. Mods: 8,000lbs of Dog Hair.
SOLD: 2003 Excursion Limited 7.3L Mineral Gray 4x4
SOLD 2003 F250 SC LB 4x4 Silver w/ the 6.0L
