Diesel Forum - TheDieselStop.com - View Single Post - V-10 Tranny troubles
Old 05-24-2003, 08:31 PM   #3 (permalink)
crich
Re: V-10 Tranny troubles
Its possible, but it was serviced 3 months ago. Unless the hotter days are causing the transmission to run a little hotter. If that is the case then where is the overflow leaking from? The boat only weighs around 2500 lbs, but I was towing hard. 75-80 mph Interstate with lots of hills. I towed the same boat 400 miles two monts ago, same driving styl with no problems.
99 F-250SD Lariat, Ext. Cab, 4WD, V-10, 4.30, Auto, Towing machine.
crich is offline   Reply With Quote
