Re: V-10 Tranny troubles
Thanks for the info Robb. I really dont think I have a problem with the TC, cause its shifting and pulling normal. I did drive it 45 miles to work today and looked at the leak when I got to the parking lot and there was no fluid coming from the grommet hole but there was fluid coming from the x-mission/shield seam. If you reach your finger in the grommet hole you will find fluid, but Im still not sure the exact location of the leak. A good friend of mine owns his own auto repair shop and has been turning wrenches on cars since to 50's swears up and down its the synthetic lube that has caused the leak. He told me to swap back to what Ford puts in and if I'm lucky the leak will stop [img]/ubbthreads/images/graemlins/confused.gif[/img].
99 F-250SD Lariat, Ext. Cab, 4WD, V-10, 4.30, Auto, Towing machine.
