Diesel Forum - TheDieselStop.com - View Single Post - ebpv exhaust brake ?
Old 06-17-2007, 11:00 PM   #2 (permalink)
DIESELDUTTON
DIESELDUTTON's Avatar
Re: ebpv exhaust brake ?
I'm pretty sure Swamps diesel has it on there website. I use the SP diesel ssebtc exhaust brake module it was around $250.00 and you can change your lock up and unlock points it works great. The instructions for wiring it up in a obs are kinda tough but once you locate the wires its a piece of cake, just a thought. Good Luck
Frank
http://community.webshots.com/user/dieseldutton
2004 Pitbull Motorsports rigid chopper
121 TP 130rwh 250 avon
04 CRF250 mine
02 CR80 sons
03 XR100 daughters
425 Polaris magnum
500 Polaris sportsman and 300 lakota everyones
1998 27.5 Wilderness 5th wheel
DIESELDUTTON is offline   Reply With Quote
