Re: tires or re-gear rear end
Thanks for that info. I like the way these tires fill the wheel well and they do look good, but I bought the truck to tow and I can not sacrifice the towing performance for looks.
Yes, there is usualy a trade off between looks & function. It takes money to have both. Do you tow more often at 55mph on 2 lane blacktop, or on the highway at 70mph? How often do you tow & how far. How often do you drive truck unloaded?
I plan on doing an exhaust, intake and a modest tuner or chip and a 6.0 trans. cooler. Will that off set the tires or would you still recommend stock.
[/ QUOTE ] These mods will definately make a difference, & I recommend them regardless. Do the mods, then decide on tire size. Add Guages to your list, Exhaust Pyrometer, Trans Temp & Boost are good to start with.
I dont mean to ask redundent questions but I need to make a decision on swapping tires soon. I bought them from Discount tire and they guarantee your satisfaction.
[/ QUOTE ] How much time do you have before you can't take them back? I'd get modding right away, anything is a good reason to mod.
I have a US Gear, which makes my 3.73's closer to 4.56's. With the US Gear, you can run bigger tires & Tow. Then when unloaded, you can run in stock gearing for highway mileage. One thing to remember is, Bigger tires generally result in lower fuel economy.
Don't sweat the questions, yours are normal & there are many on here who enjoy helping others. Great Site.
My Photos----- BTS BUBBA "Life Member"
2002 7.3L Excursion 4x4, FTVB, MBRP 4" SS Exhaust, Rancho 9000X shocks, "V" code Front Springs & "B" Code Rear Springs, Ride Rite AirBags, Rear Hellwig Swaybar, Cut Front BumpStops, DieselSite Ext Trans Filter Kit - Coolant Filter Kit & 203 stat, "Scotpart" mod, "Hutched & Pooned", "LandYot" Radius Rods US Gear Overdrive 75mph @ 1750rpm's
2001 7.3L F350 CC LB 4x4 5" Exhaust, pillar guages, BTS Trans, US Gear Underdrive, DP 6 pos chip, V10 Trans Cooler, DieselSite - Coolant Filter Kit, Evans Coolant, 203 stat, DI reg Fuel Return, GT38R BB Turbo, AFE 2 Intake, Banks Intercooler, Air Rite Bags,
2000 Excursion Limited V10 4x4 7" Lift
"Family of 5 saved by Grace"
