Diesel Forum - TheDieselStop.com - View Single Post - 96 Chevy 350 In Suburban Dumping Fuel Out Exhaust
Old 06-28-2007, 09:36 AM   #1 (permalink)
Birken Vogt
My Photos: (9)
Yes, same old Chevy...ran good for a couple days after some previously seemingly unrelated problems, then started dumping a bunch of raw fuel out the drivers side exhaust. Codes set are P0300 (multi cyl misfire) and P0301 (#1 misfire). Raw fuel is pouring out the exhaust joints on that side onto the ground. O2 sensor scan shows the passenger side bank is working normally but the driver side is off the scale of course. I am guessing an injector valve stuck wide open? Need to replace the big block that all the injectors go into?
Birken
Birken Vogt is offline   Reply With Quote
