Re: 96 Chevy 350 In Suburban Dumping Fuel Out Exhaust
Birken, that year has the infamous injector poppets which are prone to clogging. As far as fuel dumping out of the exhaust it is most likely a bad plug or wire or cap not burning any fuel in the suspect cyl. The most common overfueling issue with that style fuel injection is the fp regulator, (very very common), it is servicable, it is mounted on the fi block under the plenum.
Good luck, Tim
06 3500 QC/LB/SRW/4.10/48RE/5.9/ Inferno red pearl
04 Hitchhiker 34.5 RLTG, Kubota B7610
