Re: Transmission Temp
that plug doesnt give a 100% accurate reading of the fluid temp. the best way to do it is get a kit or a shop to install the sending unit in the cooler lines. you'd be suprised what a differnce you see, and how much quicker you see it. i would say if your gauage is reading that temp in the factory plug on the side of the tranny, your actual fluid temps could be even hotter. when i had my tranny done i had them put one in the hot side and one on the cool side coming out of the cooler. im yet to hook up another guage on the hot side though. but yes as stated before, those temps seem way too high, i would hate to see what they get to pulling any weight or sitting in traffic. aftermarket tranny coolers are fairly cheap and pretty easy to install, i would definitely look into one. good luck.
-Dan
1996 F-250 PSD, 195k, 4x4, Supercab, LB, 3.55's, 4" lift, Built Auto with Precision converter, 150cc injectors, Autometer Z-series Pyro/Boost/Tranny/Diff guages, DIY open element intake, Sandpiper Diesel Performance 4" exhaust, TS 6pos. chip with 2L Motorsports tunes, Shimmed FPR, Modded IDM, Stainless HPX mod from ITPDIESEL.com , Baldwin Coolant Filter from Dieselsite.com , Bilstein shocks on all 4 corners, 315/75 BFG A/T's on 16x10 black Rockcrawlers, Custom front bumper, Ranch hand rear bumper, Warn manual hubs, Sparky's AIC, Full chrome grille,
318hp 643tq
#24
sitting in the garage: 6.0 Intercooler
My Webshots
[URL="http://www.thedieselstop.com/forums/
