Re: floorboard vibrations
After a drive check your wheels for heat,could be a dragging brake or a worn out bearing.If you have a clutch your flywheel could be going bad.If you have an after market DP,it could be rubbing the body.
97 F-250 PSD 4wd 5spd 4.10 open SCLB, Tymar intake, 3"dp, EBPV gut, Boost/Pyro gauges, SBC Con-O, Stancor 586-902 GPR, Royal Purple gear and tranny oils
'87 Tbird TC Auto
'87 Tbird TC 5sp
