Diesel Forum - TheDieselStop.com - View Single Post - Coolant flushing procedure
Old 07-06-2007, 09:32 AM   #6 (permalink)
NCHornet
NCHornet's Avatar
Re: Coolant flushing procedure
Here is a simpler way that does the job just fine, just very boring.
Drain petcock into 5 gal bucket, refill with tap water, drive truck until heater blows hot, drain petcock into bucket, repeat this until nothing but water comes out, took me 6 times, then drain petcock and fill with bottled water, drive until heater blows warm, drain, do this 4 times, on the last dump, fill with 4 gal of concentrate coolant, and you are done, top off with concentrate as needed.
You will need 20 gal of distilled water, and 4 gal of coolant. I hope this helps.
NCH
2000 Ford F350 4X4 Auto,Crew Cab Lariat, Western Hauler Package, Long bed,
Isspro EV Guages on A-Pillar, Coolant change from Green to Gold to Red,
SCT XCalibrator2 with DP's 60 tow,80 econo,120 Race
Fumoto Valve, Marinco Mod, Homemade CCV MOD,Fuel Neck Mod, KMC Wheels at all 4's
Monroe Reflex Shoxs, SS/Kevlar Brake Lines,
FTVB from Greg Evans,Ford AIS Intake
Coolant filter,Walker BTM, Attwood Gooseneck ball flush mount,6.0 cooler, 2002 headlights & corners
Zoodad Mod,Cyro'd Powerslots and Hawks LTS Pads. 2005 front grill
Turbo Lifesaver, Infinity Refrence x4, powered by Infinity Reference amp, sounds awesome!!
Towing a 2005 HORNET 30BHSS 8500 LBS,
Stopping it with a Prodigy P3 Controller
Friends Don't Let Friends Drive Trucks With Generic Tunes!!
White Stroker
NCHornet is offline   Reply With Quote
