Diesel Forum - TheDieselStop.com - View Single Post - Intercooler clean-up
Old 07-21-2007, 11:55 AM   #4 (permalink)
smcinrox
Re: Intercooler clean-up
I used dish detergent to clean mine. Took the CAC out, laid it on the driveway and filled it to the brim with a mixture of warm water and soap. shook it around, let it soak, poured it out, flushed. Kept dooing this untill the water came out clean. Probably 4 or 5 times.Made sure the last flush was really good. I then hooked up heat gun on the cool setting (just blows air with no heat) to one side of the CAC. set the CAC up verticle and let it run for a few hours to dry the inside out.
Early 99, 3/98, F-350 7.3L Lariat, Auto, CC, LB,
Keystone Cougar 5th wheel (UVW 7120 , GVWR 10220)
ISSPRO Gauges - Column mount - EGT, Boost, Trans. Temp
DBelectric 170 amp alternator
Swamps rebuilt AD injectors
Walker Big Truck Muffler
AIS intake
Zoodad mod
AIS fender sleeve mod.
Fuel return shimed to 65 PSI
CCV Mod
DP Tunes, 40 & 60 Tow, 80 economy
AutoEnginuity
smcinrox is offline   Reply With Quote
