Diesel Forum - TheDieselStop.com - View Single Post - Air Flow Questions
Old 07-21-2007, 12:10 PM   #1 (permalink)
rmajor
Air Flow Questions
I have a 2000 F350 7.3, crew/dually, 2wd. Had it for 2 months. Stock, as far as I know. Pull a small boat and have a slide-in camper (3400#). Truck runs good, but would like to increase the air flow (or decrease restriction). Just bought an Airaid intake. Based on some reading, I was thinking of adding another duct to the air box. Does the existing air duct allow the turbo to pull the air with ease or would more airflow into the box help? Maybe the filter is still the limiting factor for airflow and it doesn't need another duct? This is a volume versus turbo need question. Technical insight is appreciated.
Also, I have a standard exhaust system - but no cat. Was thinking about a dual exhaust to lower backpressure. Maybe a larger single exhaust is just as good. Don't know that I want to get rid of muffler, truck is loud enough as is. Plan to install gauges for EGT, Trans temp & Oil temp. [img]/ubbthreads/images/graemlins/smile.gif[/img]Thanks
rmajor is offline   Reply With Quote
