Diesel Forum - TheDieselStop.com - View Single Post - A good reason to run B100 over SVO
Old 08-06-2007, 11:27 AM   #7 (permalink)
Spencnaz
Spencnaz's Avatar
My Photos: (14)
Re: A good reason to run B100 over SVO
Even still, no way I"m running WVO heated or otherwise. I had to tear down a friend's 6.2L GM that had seized due to running WVO.
Even heated it scored the cylinder bores and left this peanut butter consistency goo in the bottom of the pan.
While I'm quite sure alot are running WVO successfully in their vehicles, I prefer running a fuel that's thinner by default and has gone through a rigorous chemical and mechanical quality process before running it even in the old Powersmoke.
Spencnaz is offline   Reply With Quote
