Diesel Forum - TheDieselStop.com - View Single Post - Truck getting older ..... Towing getting tougher
Old 08-06-2007, 10:13 PM   #6 (permalink)
sixiron
sixiron's Avatar
My Photos: (11)
Re: Truck getting older ..... Towing getting tougher
I had similar issues with my older 98 PSD van...heat gauge rising during towing, temps would rise going up hill and drop going down hill...level ground was normal ...had a lot of miles on it at the time and thru a lot of parts at it that needed to be replaced anyway but no real improvement... thermostat, water pump, pulleys, belts etc...
culprit was a partially clogged radiator...had about 30% of the tubes clogged...replaced and no issues
2002 E-350 ext. cargo..4" DP+exhaust/gauges/ CCV mod/ AIH delete/TT mirrors wC-btr's/Racor prepump/ITP regulated return w/fuel bowl delete/tank mods/203*/timbrens/bilstein/Hella/ DP tuned/BTS trans/ alum baja wheels/cryo rotors...dyno 335 hp...308,272 miles
04 VW TDI/PD Jetta wagon
TT bushings, Koni'sEuro HID's,tint,
cat 2 mic f/filter,CCV/muffler/fuel filler mods,skidplate, RC1+
sixiron is offline   Reply With Quote
