Re: EGR cleaning on 03 6.0L
Ok well I am getting the code P0401 so that more than likely is the egr valve being clogged right? I went and bought the o ring kit from ford got my carb cleaner to clean off all the carbon build up, took out the two bolts that hold the valve in and spun it a little bit to have access to the tabs tried to pull it up nothing, tried to loop some wire through the tabs and wiggle side to side nothing, tried to grab it with a rag and channel locks nothing, any pointers for this, I know im not trying really hard for fear of breaking something else, but also afraid that after i get it out and clean it and put it all back together that my truck is not going to run at all because of the KOEO test.
2003 6.0 Auto Crew Cab Short Bed FX4 Lariat Edge Platinum with Attitude. 2009 Weekend Warrior FS2600
