Re: I hate towing with my new truck, Why?
You've gone from a very stable platform to about the most unstable one you could have. You have a jacked up, big tired, short wheel base truck. The SRW doesn't help a lot either. You could lower the truck and go back to stock tires but just as bad, IMHO, is the short wheel base. It being a crew cab helps you out a little but won't make up for the tires and lift. I think you just have to get accustomed to the different truck and the way it handles unless you want to spend a lot of money on it.
Joe
2002 F350, Crew Cab, 4WD, ISSOPRO Gauges,
3.73, Auto, 2wd low range mod, No door dinger,
Interior lights off switch, Zoodad Mod,
Extra Trans Cooler, Before coolers trans fltr,
Coolant fltr, Crimestopper remote start/alarm
Oil Guard Bypass, Air horns
