Diesel Forum - TheDieselStop.com - View Single Post - LEAKING FUELTANK!?
Old 08-19-2007, 03:34 PM   #1 (permalink)
REINB
LEAKING FUELTANK!?
Hello all,
I have been running B100 in my truck (2004 6.0) for around 20,000 miles and I have not had a single problem. However, the other day I noticed a black spot on my concrete drive. After sliding under the truck to inspect it looks as if the fuel tank is leaking. The frame rail, skid plate, etc. are all damp. I think it must be coming from the top of the tank & seeping down. I thought that all new vehicles used rubber compounds that were ok with biodiesel. I don't know if it matters but I have a tool box tank (91 gal.) I have been keeping this full for the past couple of months. It just feeds the tank via the filler neck, keeping the stock tank full at all times. I shut the tool box valve off so that the main tank level would drop and hopefully so would the leak, until I can fix it. What do you guys think?
2004 F350 CREW CAB - LONG BOX
REINB is offline   Reply With Quote
