Re: LEAKING FUELTANK!?
Hey,
Thanks for your response. It only has one tank. It is an F350 Crew Cab - Long Box. Yes, the tool box kit was purchased from Northern Tool. It is very simple though, it does not use a check valve. It has around a 3/8 or 1/2 inch outlet line that runs into the a "Y" adapter that is inserted into the fill neck. When the tube gets full the flow is stopped. All of those connections and hoses look very dry. It has been in use now for almost a year. I just wonder why now. I don't even know what is on top of the fuel tank to leak? It may have a bad spot in the plastic? Any ideas? [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/shrug.gif[/img]
2004 F350 CREW CAB - LONG BOX
