Diesel Forum - TheDieselStop.com - View Single Post - Home Baked Polymerization test.
Old 08-20-2007, 02:56 PM   #2 (permalink)
airfooter
airfooter's Avatar
Re: Home Baked Polymerization test.
Very cool. Thanks for your effort. I'm also curious about reaction with other metals.
I've seen the most severe polymerization in a steel tank w/copper heat exchanger, and also saw it in an aluminum tank w/copper HE.
It is interesting you didn't get the reaction until higher temps...
Those temps are much higher than most would see in a conversion system or even pre-filtering.
Keep up the good work!!
Choose wisely. Or PLEASE post pics of the carnage!!!
2001 F-350, DRW, 4x4, XLT Crew Cab, flat bed, 7.3, 6 spd, Dipricol Optix gauges on pillar - EGT, Boost, Fuel Press., HPO Press. - No Muffler, AIH delete, SB Con OFE, AC code injctrs, GTP 38R. Vegistroke-inspired WVO system w/150,000 trouble-free miles! BTS tunes, 203 t-stat w/billet housing, Evans coolant, coolant filter, boost relief valve, Dieselsite IC boots, Hella headlight harness, '07 grill/lites and big, bad front bumper!
2000 Excursion 4x4 Limited - BTS trans and tunes, AIS, Frybrid/V3 SVO conversion with over 100k VO miles so far!
That's 250k miles on SVO between them!
airfooter is offline   Reply With Quote
