Diesel Forum - TheDieselStop.com - View Single Post - Home Baked Polymerization test.
Old 08-23-2007, 03:03 PM   #6 (permalink)
scottefontay
Re: Home Baked Polymerization test.
As a previous reply said, use biodiesel to see how it affects the WVO also, that could be very interesting. In the top three you could try straight biodiesel, strait WVO, 10:1 WVO:BD. Then duplicate those tests inthe bottom three cups. It might be best to try three variations at a time, with two of each for reapeatability in identical conditions.
As as a side note Jason, if y'all are using #2 in the primary tank with a veggistroke-type configuration, the purge would input #2 into the veggy tank as a matter of course. It would be a function of tank size and purge time to target desired #2 and WVO ratio. If your preliminary 10:1 results with No. 2 are any indication, I feel alot better about a few of the steel fittings I have in my system!!
Thanks for the hard work.
2000 F-250 Super Cab Longbed
Bright red, they call me "Clifford"
scottefontay is offline   Reply With Quote
