Re: Timbren vs. Airbags
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Kanman</div><div class="ubbcode-body">Man oh man, this post is the blind leading the blind...
If you want cheap, buy Timbrens. You get what you get period.
If you want an infinitely variable solution for loaded and unloaded buy the airbags.
Here is a hint. Look under a big truck, look under ANY big truck. You will never find a set of Timbrens. But, just about every big truck on planet earth has air bags. I wonder why????
</div></div>
If you don't want to infinitely vary your solution for loaded and unloaded buy Timbrens [img]/forums/images/%%GRAEMLIN_URL%%/grin.gif[/img]
In all seriousness there are a lot of variables. I will grant that the ride while loaded is probably better with air bags. I personally just don't want to mess with them. I installed the Timbrens and forgot about them. Price had nothing to do with my decision and I am very happy with the Timbrens.
Buy Ford. They're not taking bail-out money.
2000  F250 XLT PSD Crewcab, Longbed, 4x4, Auto, LS 3.73
Ford AIS, Frantz Bypass Oil Filter, Baldwin Bypass Coolant Filter, Fumoto Drain Valve, 203* Thermostat, Stancor
Bilstein Shocks all the way around, Timbren SES (Rear), Bridgestone Dueler Revo A/T 265/75/16
Commander Monitor (gauges), Crimestopper CS-2016 DP II FM Remote Start/Alarm/Paging/Turbo Timer/Keyless
Rotella 5W40 Oil, Texaco ELC Coolant, Mobile 1 ATF Trans and PS
My mods, repairs, and other truck Stuff
