Diesel Forum - TheDieselStop.com - View Single Post - What Happens When....... Brake Controller Question
Old 08-27-2007, 04:02 AM   #6 (permalink)
larry_minn
Re: What Happens When....... Brake Controller Question
Something is wrong somewhere. I have NO idea where. I have one 3 axle trailer and pair of two axle. The two axle controller works fine I just have to set it (higher) for three axle (to get similar results) then for 2 axle. It lacks the power to lock up all three unless set at max.
From what you say it needs to be fixed. I would likely get correct controller and install it. (Or hook trailer to friends truck that you know the controller is working and see if problem is trailer/truck side.
larry_minn is offline   Reply With Quote
