Diesel Forum - TheDieselStop.com - View Single Post - HIH vs HOH
Thread: HIH vs HOH
Old 08-27-2007, 04:28 PM   #5 (permalink)
hheynow
hheynow's Avatar
Re: HIH vs HOH
My system has my own take on HOH. I purchased 25' of CHEAP coolant hose and cut pieces to match the lengths of my installed hose. I slit each piece lengthwise and wrapped each hose segment secured by tie wraps. The now double insulation has given me cold weather protection. I've run it in ambient temps as low as 19*F without a problem. Another cold weather accessory should be a cold front blanket to cover most of your grill/radiator. The combination of these two makes winter WVO driving easy.
'97 F-350 7.3L PSD RC LB 4WD E4OD - Plant Drive VO kit
'84 Mercedes Euro 300D NA - Custom two-tank VO
Running on Veg Oil and Biodiesel since May 2006
hheynow is offline   Reply With Quote
