Diesel Forum - TheDieselStop.com - View Single Post - Fix your fuel leak from filter drain valve
Old 08-28-2007, 05:05 PM   #18 (permalink)
hheynow
hheynow's Avatar
Re: Fix your fuel leak from filter drain valve
A great product to trace fuel leaks is Spectroline Gas-Glo p/n 1U-5574. It's a fluorescent dye designed to be poured into the tank and fluoresces under black light at the point of the leaks.
'97 F-350 7.3L PSD RC LB 4WD E4OD - Plant Drive VO kit
'84 Mercedes Euro 300D NA - Custom two-tank VO
Running on Veg Oil and Biodiesel since May 2006
hheynow is offline   Reply With Quote
