Diesel Forum - TheDieselStop.com - View Single Post - Clutch in to start - Switch delete??
Old 09-05-2007, 03:24 PM   #6 (permalink)
MarkEkberg
MarkEkberg's Avatar
My Photos: (13)
Re: Clutch in to start - Switch delete??
You can do exactly this. Behind the right pedal there is a grop of wires that go into a plug. It is on one side or the other at the extreme end. One of the wires is white with a pink tracer. The other wire is right next to it.
I used a blue spade connector. I drilled out the side that stops the wire so it would fit over both wires at once. Clamped it tight and never looked back.
UPDATED 1/1/09 Replace so far. 1 LUK flywheel+clutch, 2 thermostats, 2 set of brakes, 1 set of calipers, 5 CPS, 3 sets of tires, 2 Transfer pumps, 1 Injector modual, 1 Computer, 2 Alt, 2 sets of batteries, 1 Water pump, 6 Belts, 1 PS hose, 2 Sets ball joints, 2 set u-joints, 2 carrier bearing, 2 Speed sensors, 1 oil pres sender, 1 temp sender, 4 sets of e-break cables, 1 front fuel tank, 2 rear fuel tanks, 2 set of glow plugs, 7 Glow plug relays, Oil galley o-rings, Turbo pedistal o-rings, EBPV o-rings, 3 sets of Injector O-rings, 1 Vac-pump, 1 new carpet, 1 total paint job.Total $$$ in repairs v/s miles driven = 4.6 cents per mile. Add fuel to that it jumps to 16.5 cents per mile over the life of the truck.
MarkEkberg is offline   Reply With Quote
