Re: Clutch in to start - Switch delete??
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Believer45</div><div class="ubbcode-body">An automatic has a jumper installed in the plug for the wiring harness, I do not know if this will also disable the cruise cutout when you release the clutch though.
</div></div>
Has anyone with a stick gone this route, and does it cancel the cruise?
Let me get this right, Dave - the wiring harness that plugs into the clutch safety switch has a jumper that is included with the auto trucks to bypass the clutch safety switch feature. Does anyone have a PN for this thing? It is hard for me to get to a JY, and this might be quicker.
Mark - did jumpering those wires let you use your cruise control?
Kurt
SOLD!!
1997 F350 XL PowerStroke 4WD, ZF-5 w/ South Bend Con OFE Clutch
Regular Cab, Long Bed, SRW, 3L55's, Bilstein shocks, Warn premium hubs
3-inch downpipe/4 inch exhaust w/ Magnaflow muffler and cat
Tymar intake
International Water Pump with integrated filter
Wildman Four-Position Chip; Baby Swamps; D66 turbo with 1.00 housing; SD HPOP
Isspro EV Boost and Pyrometer gauges
285/75R16 E-Rated BFG All Terrain KO's
Rear Disc Brakes from Blackbirds Custom Trucks
Pictures of it all...
