Re: HIH vs HOH
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Repower</div><div class="ubbcode-body">Do you think they would work for the rear tank on a super cab in your environment , pretty similar here in Michigans U.P.? And if so,is there a plastic tank and heated pickup close enough to custom fit where the rear tank and spare are ? (36 x 36 x 12) </div></div>
You should put your truck configuration in your sig, so we can see what we are commenting on.
I know of no where that HIH won't work... (Vegistroke or otherwise)... it's just a matter of whether or not you want to run heater hose and fuel line separately or inside one another.
As far as tanks in the spare tire area, I think a few folks have taken Excursion fuel tanks and have managed to rig them up for use in their SuperDuty trucks... (but if pressed, I couldn't recall who did it or when).
Halitosis
'02 Ford Excursion Limited
7.3L PSD -- 170,000 Miles
Hellwig Sway Bar
Firestone Ride-Rite Air-Helper Springs
203* Thermostat
Teconsha Prodigy Brake Controller
Sirius Satellite Radio
1995 BMW (Euro-spec!) M3
1974 Human Wife
2002 Human Son
"7/5 children suffer from ADHD... won't you help?"
(Running Vegistroke WVO system (HIH)--> 75,000 MILES AND COUNTING!)
