Diesel Forum - TheDieselStop.com - View Single Post - Fix your fuel leak from filter drain valve
Old 09-07-2007, 03:17 AM   #21 (permalink)
klhansen
klhansen's Avatar
My Photos: (169)
Re: Fix your fuel leak from filter drain valve
Here's some part # info from This website
Fuel Filter Housing Reseal Kit
(International) 1823645C91 (94-95) (Part # inside Ford packaging, bad per IH)
(Ford) F6TZ-9157-BA (96-97)
(Ford) F5TZ-9157-A (94-95)
Includes:
(Ford) F4TZ-9C064-A O-Ring Water in Fuel Probe
(Ford) F4TZ-9C065-A O-Ring Heater Connector
Not Available (International) 1823565-C1 O-Ring Water Drain Valve
Not Available (International) 1823635-C1 O-Ring Orifice Vent
Not Available (International) 1823644-C1 O-Ring Pressure Regulator Filter
Not Available (International) 1823655-C1 Ball, FPR Check Valve
Not Available (International) 1823662-C1 Gasket, Element
Not Available (International) 1824476-C1 O-Ring, Prescreen Bowl
Hard or no-start? Check Here
