Diesel Forum - TheDieselStop.com - View Single Post - Clutch in to start - Switch delete??
Old 09-07-2007, 10:58 AM   #11 (permalink)
BigBadLou
BigBadLou's Avatar
My Photos: (14)
Re: Clutch in to start - Switch delete??
To answer the cruise question clearly:
the start safety switch is separate from the cruise cancel switch - yes, it is in the same switch assembly but these two use separate wires.
So if you bypass the starter safety switch, your cruise control will still function correctly, just leave the black plastic cylindrical swith on the clutch rod, do not remove it.
Lou
1994.5 F350 5-sp 4WD CC LB 4.10, RanchHand bumpers, 35" BFG's;
VV 6.0L turbo, 3" DP, 4" exhaust, el. fuel system, open element intake, onboard air with 30" Grovers, el. fans, SD Intercooler ... (+ 20 other mods)
BigBadLou is offline   Reply With Quote
