Re: Clutch in to start - Switch delete??
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: ironcwb1</div><div class="ubbcode-body">Also, consider where the bushing is in the pushrod, if it had metal to metal wear (when the bushing went out) this will make a difference in starting. I know this firsthand and dealt with it for months before replacing the whole master cylinder. That could be the starting problem, as it was for me. </div></div>
Iron what kind of problems did this give you? I cut the two white wire(with tracers) and spliced together. It did not work. So I put my new switch I still have the same problem some time it does not want to start. Radio and A/C go off when I have turn the key but it acts just like the clutch is not depressed. Please help on this. I am not out of ideas and 40 bucks.
Clint
95 PSW with 5 Speed Manual. 200,000+ miles.
LUK Clutch, 3" Downpipe, 3" Straight Exhaust, Tymar Intake
