Re: Clutch in to start - Switch delete??
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Ckill</div><div class="ubbcode-body">If that is the case I spliced the wrong ones initially. All I should have to do is twist them together correct? </div></div>
Please don't rig it like that, atleast splice it with a connector.
If you aren't gonna use the switch, bust it apart and see what the contacts connect when the switch is activated. Full proof way to find what wires to connect.
Sold, back when the snow was on...
1997 PSD 3/4 ton 4x4 SC LWB SRW; 5 spd; 3:55; K&N open element/homemade intake; gutted EBPV piston, plugged hole; 3 in. downpipe; SCMT 1705; shimmed to 70 psi; 120,000; TTB  DiPricol 0-60 white face boost gauge, DiPricol 0-1600 white face pyrometer, SOLD in between gauges for now; A-Pillar mount for now. DIY 160cc Injectors.DIY IDM mod. ValAir O-FE w/3400# plate; Front and rear tank filler neck mods
My Pics
Truck Pics -Updated-
