Re: Auxillary tank under the bed for 2008 F350?
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: tonystrong</div><div class="ubbcode-body">I've got a 2008 F350 SB CC 6.4. I guess when they ordered it the optional 30 gallon tank wasn't checked on the form. It only takes 20 gallons when filling it up and that's quite annoying when hauling the race car or the boat.
Does anyone make an under the bed auxillary tank for the 2008 SB? It would be nice to be able to go more than 200 miles before filling up on road trips. </div></div>
Wow that is a small tank. Are you sure its not a 30 gal? Have you tried filling it all the way up till you see the fuel, and not when the pump shuts off?
Ryan Kranz
2000 F250 Maroon lariat ext cab, short bed. 2.5" leveling kit, Ranchhand front replacement, custom Headache rack, 285 Revos, Rancho Steering Stabilizer, Tymar, 4" turbo back exhaust (no muffler), Wicked wheel, quad pod with Dipricol optix (boost, pyro, trans, fuel pres), Steering column pod with optix HPOP guage, DI 6 position chip (40, 60, 80, 100, 140, high idle), Fumoto, dieselsite BRV, custom made turn over goose neck hitch, clear corners, silverstars, Cobra 29 CB, CCV, Blue IC Boots, TC lock up switch, LED side marker lights, cab lights with smoked lenses.
Let freedom ring and the turbos sing.
People that have treated me right:
DI, Diesel Power Products, SP Diesel, Dieselsite, ITP
302 HP/720 TQ (In the 80 setting)
If it dont smoke black, take it back
picts
