Diesel Forum - TheDieselStop.com - View Single Post - Auxillary tank under the bed for 2008 F350?
Old 09-12-2007, 01:04 AM   #8 (permalink)
westvandude
westvandude's Avatar
Re: Auxillary tank under the bed for 2008 F350?
That's really odd. Ford.com F350 specifications show either 30.5 or 38gal fuel tank depending if you got the short or long bed. Can't have a big tank with the short bed. If you only get 20gal in your 2008 truck then I'd suggest you head to the dealer and tell him your fuel sender is broken.
2001 F250 4x4 crew lariat 7.3L auto, DP Tuner F5 no-start/valet/20tow/80econo/140aggressive, Adrian Tavano's triple disc converter, transgo tugger HD2, ISSPRO egt/boost/pyro, foil delete, 6" stainless tip, Magnaflow 17979 4" turbo-back, dieselsite boots & coolant filter kit, HX crossover, boost fooler & tru-cool trans cooler, ported turbo housing, DIY 6637 Tymar, billet grill, line-x bedliner, bug deflector, tint, 08' alum diff cover, clear corners & tails, silverstar bulbs, Xtreme XT855 reverse lights, 1500w inverter, Tekonsha Primus, EQX, Epicenter, Autotek MM4000.1D, 2x Audiobahn AWT12X, 2/0 cables, JVC KD-AVX44 El Kameleon dvd deck, 12.5" flipdown video.
2009 VW Jetta 2.0TDI 6spd Highline full load except nav. 19" Audi RS6 rims. Custom fiberglass hifonics 12" sub & 280w usacoustics amp. Tint is next.
westvandude is offline   Reply With Quote
