Diesel Forum - TheDieselStop.com - View Single Post - Auxillary tank under the bed for 2008 F350?
Old 09-13-2007, 06:52 PM   #13 (permalink)
jetskier
jetskier's Avatar
My Photos: (23)
Re: Auxillary tank under the bed for 2008 F350?
I still can't figure out why they don't offer a larger factory tanks based on your cab configuration AND bed length. It's great Ford finally started offering variable GVWR based on the different cab/bed configs (click the Payload Package Selector). Since they are only getting 8-11 MPG when towing (if you're lucky), it be nice to have the extra capacity from the factory.
Here's what must fit because the aftermarket does it:
RC LB (137" WB) - 38 gallon (standard)
CC SB (158" WB) & SC SB (142" WB)- 46 gallon
CC LB (156" WB) & SC LB (172" WB)- 57 or 60 gallon (new for 2008 TF)
If companies like Transfer Flow and Titan can do it, why can't the factory? Wake up Ford!!!
2000 F350 XLT 4x4 CC LB SRW, PSD, 4R100, MSOF, 3.73 TrueTrac, OTC, wired keypad, AIC, DRL, Gauges, DP F6 Live Tuned, Ford AIS w/ sleeve & Zoodad, ATS housing, 31-row trans cooler, HPX line, Magnaflow & BrakeSmart.
jetskier is offline   Reply With Quote
