Re: Anyone tried this "diesel secret energy" additive instead of making biodiesel?
Like they say, if it sounds too good to be true, then it probably is.
I use the stuff. This is my second summer season using it. This process doesn’t work well in cold weather. I put on 25-30,000 miles a year, but only use blended WVO from May through October.
In reading other posts here and on other forums, I probably will discontinue using the magic elixir when my supply runs out and just make my blend without it.
As far as the costly repairs that I will have using this method, I’m still waiting. I did have to replace my IP at the end of my first season using blended WVO. But there was 198,000 miles on it. I also had to replace my radiator, clutch and have my tranny rebuilt last fall too, but I don’t think the blended WVO caused that,
The DSE magic elixir probably is a scam, but like was said before, at least it got some of us started down the alterative fuels road. And with time, who knows, I might even cross over to the biodiesel side someday.
Jody
The only thing wrong with doing nothing is you never know when you're finished!
'98 Chev 2500 6.5 TD 4X4 longbox ext cab. 5spd man trans, LUK clutch, 220,000 miles. 3" downpipe, 4" exhaust, 5" tip, 80hp upgrade, marine injectors and fsd heatsync w/#9 resistor
IAFF Local 1935
