Re: ARP Studs - Questions
If I can blow my head gaskets stock at 18k miles, anyone can. If it was caused by warped heads, then anyone can get warped heads as mine were straight when the gaskets were replaced.
Let me answer your questions:
1-Run lots of power reliably
2-Put stock TTY bots back on.
3-Unlikely unless the dealer has no idea what they are doing or you decide to run boost pressures higher than 50psi.
2004 F250 CC FX4 / 46g Transfer Flow / ARP Studs / Coolant Filter / CCV
2004 Surf Side 30' pull trailer
1999 Pontiac GTP modified
1968 Pontiac Firebird (restored)
