Re: WVO tank sending unit
Thanks again , since you brought up the fuel pump... I plan to use a seperate pump to supply WVO and use check valves to eliminate switching . Where would you mount the new pump and could I tie the original pump to the tank switch to shut it off when I switch over ?
93 F250 Super Cab 4x4 E4od 231,000 mi
