Re: Seprentine belt - but what about the fan clutch wires?!
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: khitch710</div><div class="ubbcode-body">I had a Job 2 '04 built in Oct 2003...mine had the squeeks running and shutting the truck off...Ford came out with a bulletin for the belts...they now have updated belts that elimate the squeek at shut down....maybe if you are buying new belts from Ford they should be the updated belts....hope this helps...Kevin </div></div>
I had the squeak and a new belt installed at around 50K or 60K and the squeak went away. I've got 93K on the clock now and I also have the squeak when the engine is cold (had not run today) and outside temps are in the high 40's low 50's. The belt looks great, no cracks etc. Time to change it again??
2004 SD F-250 4X4 Supercab 6.0 - TorqShift
Dark Green Satin Arizona Beige Met Accent Lariat 142" WB Styleside Pkg 608A, 3.73 LS 8800# GVWR, Electronic Shift on the fly, Telescpng TT mirr-powr/HTD, FX4 pkg, Skid Plates, Adj. Gas/Brake Pedals, Reverse Aid Sensors, Hitch Reciever 15K, Heated Seats - Ford bed liner - EGR Bug Deflector - Window vents - Billet grill - Mud Flaps - Locking Fuel Cap - Bull Ring stake pocket tie downs - Isspro gauges EGT, Trans Temp, Turbo Boost, Cubby Gauge pod - Sirius Radio - Rancho RS9000X Shocks
1995 Green Taurus SHO mini-mods
1988 Arrest Me Red Corvette 380rwhp many mods
