Diesel Forum - TheDieselStop.com - View Single Post - 08 F350 axle gears DASH / COMPUTER question...
Old 10-20-2007, 02:54 PM   #5 (permalink)
ritschner
ritschner's Avatar
Send a message via AIM to ritschner
Re: 08 F350 axle gears DASH / COMPUTER question...
If the 08's are like the earlier trucks, which I believe they are, changing the axle ratio will have no affect other than RPM at road speed. The speedometer pickup is in the differencial and is induction ring is separate from the ring gear. If your speedometer is correct now, it will still be correct after a gear change. It only needs to be recalibrated after a tire diameter change. The only thing I would suggest is to reset the PCM to allow for the different loads that will occur at a given road speed. The PCM will eventaully learn on it's own, but it will probably be less frustrating to reset it. If you are worried about clock and radio settings, you can reset the PCM by removing the PCM keep alive fuse for twenty seconds. The fuse number will be listed in the owners manual.
White 06 F350 Lariet CC 2WD DRW Tow Boss, Timbren SES, Smiths Ultimate Bedliner, RK Tool Box, CondensorGuard, IntakeMod, S&B Intake, SEIC, Banks 4"TB w/cat, Accufab, Edge Platinum/w Evo Trans Tune, Harpoon Mod, Coolant Filter, Glove Box Light, Hood Insulator, Rewired Mirror Heat, Seat Heater Indicator.
ritschner is offline   Reply With Quote
