Diesel Forum - TheDieselStop.com - View Single Post - Topper/Cap brake and light wiring ?
Old 10-26-2007, 12:09 AM   #5 (permalink)
Richman
Re: Topper/Cap brake and light wiring ?
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: DWNRIGR</div><div class="ubbcode-body">Not sure if this is the correct forum, but is there factory wiring in the back somewhere to wire in the third brake light, and aux interior light on my new used topper?
</div></div>
I also used the tail light wire for the interior dome light, that way there is no chance of the light being left on.
As far as the 3rd brake light, use the green wire down by the spare tire as noted above. If you use the brake light wire down at the tail light lens, you will have your 3rd brake light flashing when you turn on that paticular brake/blinker that you tapped into sine the brake and turn signal use the same line.
2004 F350, 6.0, crew cab, long box, ISSPRO BOOST-EGT-PYRO gauges, 4" MBRP exhaust, Innovative Diesel SCT programmed, GOS Racing headlight harness upgrade w/Bright Box FLC, husky floor mats, LEER canopy, FabTech 3.5" hangers on 35" tires.
2001 GMC Yukon, all stock besides the 18" chrome wheels and the kids car seats.
1992 Toyota Terdcel.
2006 Desert Fox toy hauler.
2005 Yamaha YFZ450 - a toy for the sand.
1996 Yamaha Banshee - oh yeah, it's a ride in the sand!
Richman is offline   Reply With Quote
