Re: Fuel Filters
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: dmags</div><div class="ubbcode-body">A little thing I thought of today was when you install the bottom filter back on to the cap put the plastic bag the filter came in back over the filter while trying to position it prior to install this way if you rub drive shaft or anything you will not get shmeg on your new filter.</div></div>
Thanks, that tip about using the plastic bag worked great. Sure enough, I did get shmeng on the plastic bag as I maneuvered the fuel filter up past the front drive shaft, frame rail, and cross member.
And somewhere I came across this great PDF regarding fuel filter changes.
http://www.houstonareapowerstrokes.c...lter_Guide.pdf
2005 F250, 6.0L, Auto, 4x4, CC, LB, SRW, Lariat, 2.5" Leveling Kit, F350 Rear Blocks, 295/70R17 Nitto Terra Grappler, 17x8 AR Mojave Wheels, LINE-X Spray-On Bedliner, 2004 Glove Box Light, P.I.E. Aux Input, ScanGaugeII, High Idle Mod
