Re: 6.4 High Idle Wiring
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 2008TTCC</div><div class="ubbcode-body">So all you have to do is go under your dash by the parking brake... find the PTO (what does PTO stand for) wire, which is yellow/green, and then butt connect it to one of the Upfitter switches and you are done??? did i get that right? </div></div>
You got it! Don't forget to set your parking brake and have the truck in Park.
PTO stands for Power Take-Off, which basically allows you to run hydraulic equipment off of the transmission. Built into the PCM is the PTO strategy for idling up the engine and preparing the transmission.
